help with spark arc
---wires are new Taylor Spiro Pro OVC
---plugs are new Autolite AP106. Also tried NGK TR55.
---3 different ignition coil wires
---Opti is about a year and a half old
---ICM is about a year old
---ignition coil is MSD stock replacement.
---reseated all wires
The problem is at idle mostly. The idle is fairly rough and it feels like it is missing. Also the engine is very loud during acceleration...it isnt a normal type of loud. I have roller rockers which are loud but this "loud" is almost like I have another set of roller rockers in there. In the pitch black dark I can see an aura around 6 plugs, the ignition coil and a couple of the Opti ports. Also I can see an illumination b/w some of the wires which is probably a spark jumping from wires. The brightest illumination seems to be coming from the ignition coil but I cant tell for certain. If I give the car some throttle everything appears to go away except for the spark plug aura. Could a bad ignition coil cause these problems? Any suggestions?
