3.42s to 4.10s
You will be pleased with them. Be easy on the launch. You should get 4-6 tenths is about right. From 2.73s, expect a full second or slightly higher.
i have a 92 Z28 with a Tremec T-56 from Mcleod. rear end is out of a 02 Z28 with 3:23's.
would going to 3:73's be a good thing? the guys on the Thirdgen.org board say my car is not a "highwinder"(the hell does that mean?) and to go with 3:42's. some are saying my 1st gear will be useless if i go 3:73's
to date i have ran a best of 13.94 @ 98.89 at fontana(completely rich mixture) my 60ft was 2.194
this was my very very 1st run ever on a drag course.
so my question is what will benefit my 6 speed for usage as a daily and once a month drag?
Exactly what I was thinking.Honestly, if you guys ever do any drag racing at all with any kind of a sticky tire, do yourselves a favor and apply that $$ toward a real rearend. The only way I would install another set of gears in a 10 bolt is if it were going behind an automatic. They seem to have much better luck holding up than the 6sp cars.
Mike
