Banjo bolts
What I'm trying to find out is who else dealt with this or is it just me and my shitty luck.
Now, I don't know if you have ever saw how tight the engine bay is on LT1 Vettes, but let me tell you they are tight. I used a 15mm gearwrench to slowly turn the banjo bolt off. It was slow going but I eventually removed them, replaced the o-rings with new ones and then put the banjo bolts back on. This took me all day one Saturday back in 2003 just because of the tight space. Anyway, the bolt size should be 15 mm. If I were you, just use a 15mm gear wrench. Its tedious, but it works.
as for the aluminum crush washers, they are a must-do replacement. I learned that many years ago (before forums) and not the first time either. I thought it was just a bad washer. Stupid me!!! Oh well, learn from mistakes.
Live and learn. That crossover tube is just too much of a hassle than what it is worth.
