heads and cam lt1, 420rwhp??
thanks
bubba
thanks
bubba
I found some specs on a cam that would best fit my setup. Only Im using a Solid Roller. Bought it through thunder Racing for $260, Its a comp cam, although not a shelf cam that I know of. Even w/ my mods I dont expect to see much over 400 rwhp. You sure have some High expectations. Mods are on my cardomain page 4.
http://www.cardomain.com/memberpage/573287
There are no plans of spray or FI yet, so it is for a N/A car.
Thanks
My previous setup was a 2 bolt 355 with SRP pistons, Eagle 6" rods, stock crank, and racenet LT1 Stage II heads that flowed 258cfm at .600 intake and 203 cfm at .600 exhaust. The cam was a 236/242 .556/.576 112lsa off the shelf comp cam extreme energy. Intake was ported with a 58mm throttle body, Hooker Lt's with a 4" mufflex exhaust. 30lb injectors and a piggyback DFI system that was tuned by Joe Overton.
Car put down 422RWHP and 397RWTQ..... And that was with a tune that Joe barely optimized since we were trying to tune out a backfire (I accidentally crossed #1 and #3 plugwire).....
Like i said it's all about a thought out combo and your car will KILL the dyno. My heads weren't all that but they fit well into the combo of parts.... My new combo is LT1 based with AFR 227's and i'd like to make 475RWHP with a TH400 and a 4000 stall converter (easily 500+ RWHP if I still had a T56 which those dyno #'s above were made with).....
