Question about true dual exhaust???
this is to anybody running a true dual setup, on your setup how much ground clearance is there? and where did you put your mufflers? i was thinking about running a 3 inch system with dumps, probably going to use flowmasters or borla mufflers just wanted to know if there will be clearance issues also I plan on lowering the car by about 1.5, will the exhaust scrape then? also i have one other question can i true dual exhaust be run without and x or h pipe? will there be any big performance lost or will it sound horrible?
