No ignition
-Jon
I would start by testing the coil
then go to the ignition switch after that. (I am assuming you know your optispark is working.) The coil is going to be way easier to do as well.
http://shbox.com/ignsw/ign_switch_repl.html
Sounds like the way the old HEI distributors would behave when the ignition module at the base of the distributor would overheat and fail.
