93 camaro speedo
Old Feb 7, 2005 | 07:14 PM
Strokinit383's Avatar
Default 93 camaro speedo
The 93 z28 used a 700r4 transmission, so does it also use a cable-driven speedo?
Old Feb 7, 2005 | 07:28 PM
Lt1FBoDy209's Avatar
i wasn't aware that Camaros used bathing suits...
Old Feb 8, 2005 | 08:26 AM
wrong speedo
Old Feb 8, 2005 | 09:09 AM
z28s's Avatar
No cable, but we still have the drive and driven gears
Old Feb 8, 2005 | 04:02 PM
How does it work? Could it be modified to run with my 89 700r4? Would it work with a 94 wiring harness?
Old Feb 8, 2005 | 04:05 PM
97LT1's Avatar
Thats just silly!
Old Feb 8, 2005 | 10:30 PM
z28s's Avatar
Yes, it will work with an 89 trans, i have a 88 trans out of a truck in mine......It more or less works like a hall effect distributor, so instead of a mechanical linkage to the speedo, it gets an electrical signal
Old Feb 9, 2005 | 10:52 AM
Will just the gauges be enough? Or will i need other pieces, wiring and etc. to complete the swap into my 1994?
Old Feb 9, 2005 | 10:26 PM
z28s's Avatar
I think the speedo issue will be the least of your worries, You should find out what you would have to do with the electrical signals that go to the solenoids in the valve body, find out if you can have your computer re-programmed without them. Remember pre '94 700r4's didnt have the solenoids.
Old Feb 10, 2005 | 08:16 AM
Im not really worried about the signals. My 700 is all mechanical, along with my complete motor. They are basically stand alone, im just looking for a way to wire up my stock speedo and how to keep the lockup feature of the tranny.
