Clutch problem...
Old Feb 10, 2005 | 04:56 PM
93ZM6's Avatar
Default Clutch problem...
Well this is the first time i havent started my car in about 3 months and when i press in the clutch it makes a loud sharp kind of grinding ticking noise and kinda shakes a little, it only does it when the clutch pedal is pushed completely to the floor, the clutch is only 6 months old (stock from GM) it scared me too much to even drive it any where what could it be?
Old Feb 11, 2005 | 07:05 PM
SouthernSon's Avatar
If your clutch is mounted the same as my LT4, then you may have the same problem that mine and others have suffered. The clutch fork pivot bolt tends to back out allowing the fork to get into the back of the clutch when the pedal is pressed all the way to the floor. In the vette, one has to pull the transmission to access the bolt and smaller set bolt that is threaded from the other side of the bellhousing.
Old Feb 13, 2005 | 12:46 PM
Chuckels's Avatar
Same thing happend to me the bolt backed out and made a nasty noise when the pedal was depressed all of the way. Pull the trans apart from the bell housing and lock tight then tighten good.
