Deleting A/C
Old Feb 12, 2005 | 08:13 AM
Abdullah's Avatar
Default Deleting A/C
my friend wants to delete the A/C in his 94 LT1 camaro to loose wieght is there a special belt available for the pullies without the compressor pulley? how much does it cost and from where? thanks.
Old Feb 12, 2005 | 09:26 AM
Strokinit383's Avatar
there is a bracket and pulley that bolts in place of your current compressor setup. try ebay, you may get lucky
Old Feb 12, 2005 | 09:49 AM
396D1SS's Avatar
They usually sell them on e bay. You can go to any gm dealership and tell them you want part # 10115875ada and they can order one for you
Old Feb 12, 2005 | 10:26 AM
WhiteBlur's Avatar
GM sales the a/c delete that they put on the 1LE cars. If your compressor is bad, it's a nice cheap way to free up alittle power and loose some weight.
Old Feb 12, 2005 | 03:20 PM
BizZzatch350's Avatar
Moderator
Use the GM 1le pully, it retains the stock belt size, its not worth it though if your ac works
Old Feb 12, 2005 | 07:05 PM
396D1SS's Avatar
The part # I listed is for the 1le bracket
