upper RPM Coughing and power loss
Old Feb 21, 2005 | 10:05 PM
z28boysteve's Avatar
Default upper RPM Coughing and power loss
well frankly my mph sucks (112 best) and at 5000 on up the motor falls on its face and coughs like mad, i put vicegrips on the fuel return line but it didnt help so its not starving for fuel, i think its the lifters or springs but is there any way to know for sure? i think im going to remove the lifter plungers and shim them near solid with washers.
Old Feb 22, 2005 | 07:14 AM
any help please?
Old Feb 22, 2005 | 09:39 AM
Crazyz28's Avatar
It could possibly be a bad coil. Mine had trouble at high RPM's when mine went out.
Old Feb 22, 2005 | 09:44 AM
OneMeanZ's Avatar
Mine does it and I believe it is the opti or coil.....
Old Feb 22, 2005 | 02:17 PM
Crazyz28's Avatar
Try the coil first (it's cheaper anyways). If that's not it, check to make sure there is no arcing in the plug wires w/ anything else. Then I'd take a look at the opti. BTW, if you have the chance, have the car scanned, as sometimes when an opti goes out it'll throw a code (35 or 36 if I can remember correctly) but it won't throw an SES light.
Ryan
Old Feb 22, 2005 | 02:55 PM
Formula94's Avatar
Valve float maybe? Either that or sounds like a typical coil/opti problem.
Old Feb 22, 2005 | 06:23 PM
is this what im after?
GM PART # 10477208
Old Feb 22, 2005 | 07:16 PM
is there any way to find out for sure if its ignition or valve float besides just changing parts till it goes away? i also need new slicks, skinnies for the front, new lifters new valve springs etc etc and i am on limited budget + going to iraq in 6 weeks.
