how do you indentify a hotcam?
Old Mar 8, 2005 | 04:26 PM
lockupman1's Avatar
Default how do you indentify a hotcam?
Hey Guys I need help really bad I got this so call hotcam but I'm not sure if it is or not. The numbers/lettering I found are "241.CPC.BC PC.BC.1" Then at the back of the cam the number "8" is found and on one of the journals there is a letter "F". I hope I explain it correctly, in any case any and all help would be greatly appreciated. Thanks in advance,
Old Mar 13, 2005 | 06:38 PM
lockupman1's Avatar
ttt..
Old Mar 13, 2005 | 06:42 PM
GhostZ's Avatar
Call Comp and see if they can help you....that would be your best bet. I don't have my Hotcam laying around anymore so sorry I can't help further.
Old Mar 14, 2005 | 10:36 AM
crow2's Avatar
GM'S "HOTCAM" Will have the following on ALL HOTCAMS~(lt4)
They will have a green paint stripe on it,And it will have the #'s 586ac on the end of the camshaft!!!! If it does not have this~it is not a hotcam!
Old Mar 14, 2005 | 06:17 PM
busta9876's Avatar
i bought a used LT4 hot cam off ebay.
I have 586 FM49 and 412 99L on the end opposit the dowel pin
there is also a green dot of paint between the numbers on the end
maybe this will help you out.
Old Mar 14, 2005 | 07:07 PM
lockupman1's Avatar
Thanks guys, all good help, my cam that suppose to be a hotcam has none of that, which tells me its an aftermarket clone hotcam, if thats what it is. In any case I really appreciate the help. Thanks.
