Guys with pacesetters
Old Mar 15, 2005 | 01:31 PM
TransAmDave96's Avatar
Default Guys with pacesetters
Im about to get a set of long tube pacesetter headers and was jsut wondering if there is anything i will have to grind down or anything to make them fit? or if theres any advise you guys can pass along.
thanks in advance,
dave
Old Mar 15, 2005 | 02:56 PM
FIREHAWK #07's Avatar
Helped my buddy put on his, and didnt have any problems.....
Old Mar 15, 2005 | 06:00 PM
wicked_95z's Avatar
put mine in from the top. Had to remove the oil filter and the a/c was already gone so it was easy for me. I think most people have to slip them in from underneath. Still very easy
Old Mar 15, 2005 | 06:15 PM
NXSLT1's Avatar
Went in from the bottom. Take the steering linkage loose and move it out of the way. I think I took my alternator off too just to have more room to work. I also dropped the drivers side header before I could get a bolt in and broke the temp sending unit, watch out for that. Had to bend the drivers side collector down a lil bit after they were installed. Other than that no biggie.
Old Mar 15, 2005 | 06:41 PM
RymerC's Avatar
Depending on how (fresh or) saggy your motor mounts are, you may have clearance issues at the collector/floorboard area. Pretty easy install. If you have a 93 (like I do) it's a good time to move your oil pressure sensor from above the oil filter to the rear of the block (just behind the manifold) where I think it is on other LT-1's.
Old Mar 15, 2005 | 07:45 PM
thanks a lot for your input, i was worried i was gunna be grinding away at my k member or something
