cam help
Old Mar 16, 2005 | 07:06 PM
BLACKDEATH's Avatar
Default cam help
im doing the hot cam kit and i want to replace the lifters and push rods. I found the lifters im going to use from comp cam but im not sure on the right size of push rods to use comp cam has a 3/8" diameter and a 5/16" for standard small block, can any body help me?
thanks
Old Mar 17, 2005 | 03:30 AM
Alex94TAGT's Avatar
The stock pushrods are 5/16" diameter by 7.200" length.
I bought Comp Cams part number 63-7808-16 from ThunderRacing-- hardened -- about $40. Depending on year, you might have hardened pushrods from factory. Mine were, but I wanted to replace them just for peace of mind...
Old Mar 17, 2005 | 02:05 PM
BLACKDEATH's Avatar
beautiful, you could not of helped me any more, thank you very much!!!!!!or wait maby one more, these push rods above are for the factory size cam, will they work with the lt4 hot cam?
Old Mar 17, 2005 | 05:00 PM
Alex94TAGT's Avatar
Pushrod length is more determined by the valvetrain geometry (heads/valve height/etc) -- not so much by the camshaft.
You should be absolutely fine, but if you want to check it for peace of mind, you can mark the top of the valvestem for the #1 intake/exhaust valves -- with a black sharpie marker, install the rocker arms and set lash, and then turn the motor over a few times. You can then remove the rockers again and check for correct contact pattern on the valvestem tip. It should be fairly centered, and fairly thin.
Like I said, you should be absolutely fine with stock length rods though. We can get more detailed with the wear-pattern check if you wish. If you think it may be off, a pushrod length checker tool will allow you to adjust until you find the correct pushrod length, and then you can measure the tool and order the correct rods.
Old Mar 17, 2005 | 05:15 PM
blind527's Avatar
When I get my new LE3 heads and LE2 cam I'll be getting the 7.200 pushrods and everything needed I'll be putting over 400 RWHP with my setup
Old Mar 17, 2005 | 05:36 PM
BLACKDEATH's Avatar
well, i called force fed performance today to get there input on the rods and they too agree will you, i should be fine.....thanks for your help!!!!!!
