Need Help Choosing Clutch
Old Mar 24, 2005 | 12:59 AM
nemanracing's Avatar
Default Need Help Choosing Clutch
I have a 96 Z28 with built LT4 6spd and i need a new clutch, any suggestions? This summer i plan on doing a rear mount turbo so i'm looking at 500-600 rear wheel horsepower, soooo what clutch would you guys recomend?
thanks for your suggestions?
oh and a decent priced place if you guys know....
John
Old Mar 24, 2005 | 01:31 AM
regorih383's Avatar
spec stage 4 , dam
Old Mar 24, 2005 | 03:28 PM
Alex94TAGT's Avatar
I'm currently running a complete SLP flywheel/clutch assembly, but I've got a new Spec 4 sitting in the garage for a blower buildup. I haven't used it yet, so I can't really testify as to how well I like it. If you can't find a vendor in the huge list of sponsors on the right side of this page, then you might try http://www.Schochperformance.com when the site gets reloaded. He had the cheapest price I found, but it might have been some sort of special...
http://hometown.aol.com/alex94tagt/i...tch%20disk.jpg
Old Mar 25, 2005 | 05:58 PM
chris77's Avatar
off the subject, but what turbo are you using that will make 500-600 hp. are you also doing heads, and cam, and the spec 2 will be a good choice, the stage 3 is a little much for a daily driver.
Old Mar 25, 2005 | 06:22 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
McLeod street twin! it sees over 800 rwhp as laughs!
Old Mar 28, 2005 | 10:40 PM
pushing over 400rwhp with built lt4 using hotcam etc, looking at using a super 60 T4 rear mounted, with long tubes no cats and programing out the rear o2 sensors, for now the motor is a 350, next year i will be building a 427 cu in LT4 bottom end and probably porting out the LT4 heads, oh yeah no egr, evap, smog pump, def not street legal in cali but oh well... so i need a clutch that can handle that... looking at the spec stage 5(spec claims it will handle 1000lb-ft, so that should be good enough for now...
Old Mar 28, 2005 | 10:43 PM
Formula69's Avatar
mcleod all the way if its really gonna be 600-800 hp... otherwise spec stage 3 at least
