failing opti symptoms maybe?
Ok, car went from not running, to runnin like ****, to not running again, It just cranks and cranks, has spark, but fires out the exhaust and intake.. popping while cranking... I hooked my pcm to it right before it stopped running, and the advance seems a little high, idling at 37 and 41 degrees!, but it wasnt hopping and erratic.. Im lost I need help
I'm also having a problem with my opti as far as i know BUT ... here's my problem....
even a SLIGHT touch of the throttle will cause my car to miss, buck etc. so here's what i did.
I pulled my opti last Sunday, didn't notice anything broken or burned or any coolant that had dripped on it. I bought a new opti from Jason Cromer and tried to compare the two. I found that when i spin the shaft from the opti going into the cam on my old optispark, i hear almost a dragging/grinding noise. On my new one i hear no such noise, very smooth.
You might try something similar when you pull your optispark. I believe that the bearings in the optispark for the sensor have been destroyed (just my opinion). This will hopefully solve my problem, but nothing is ever certain on a LT1.
hope this helps...
hope this helps...
