A4 pros/cons?
hopefully i can find an LT1 camaro for 3-4k and be a regular here
An M6 is infinitely funner and a good deal stronger, and will put more power to the ground.
An A4 will get you through the quarter quicker, but sap more power.
Another thing, this may be obvious, but if you plan on road racing get the M6.
I blew my first 4L60E with ~480ft/lbs, my second was gone after more mods.
If you plan on having a fair amount of HP (more importantly TQ) then I'd look at a rebuild from a few places that have had success with building the 4L60E. If you're looking at a high HP application somewhere in the area of >700 then I'd suggest either a TH400, 200-4R, 4L80E or T56 swap.
Building the 4L60E to hold a decent amount of power isn't worth the cost IMO as there are more viable options out there. For the price of a good build to hold 600HP/TQ you're looking at a T56 swap with a clutch that will hold whatever you want to throw at it.
i've driven dirtbikes and ATVs my whole life so i'm assuming it's the same concept but it's a whole nother world i'm sure
i wouldn't want to merge onto a freeway between semis w/ a manual not being comfortable with what i'm doing.
im more into trucks but i cant afford a good one right now. i'm 17 right now, just finishing up high school. LT1s look fun as hell. I'm a big fan of Parish's truck (02 silverado turboed w/ a 4L80E). i just like the idea of having the computer tuned to shift the auto at certain points, every time
And you're right enis....not bad for stock to full bolt-ons but you move to heads/cam and eventually you're going to burn out some clutch packs.
Parish's truck is absolutely sick...
I love that thing.As far as the A4, yeah, you'd probably have a better chance at hitting 13s than you would with a manual since you'd be a new manual driver, but LT1 cars can run anything from 13.6-14.2, so don't be disappointed if you don't break into 13s right away. With a little bit of practice though, you should be fine.
I'm in the market for a new LT1 also, and the one major thing that will determine your purchase will be the over abundance of A4s on the market, and the lack of M6s. I haven't found one M6 that fits the parameters I'm searching for, but have found close to 10 A4 cars. It sucks.
Now $2500 later, I have a 4L60E that's built to hold 1000 lb./ft. of torque.
Moral of the story: a good investment is one that keeps your hands free for other things
Also, if you're a truck guy, you don't need to know how to drive stick. I've raced dirt bikes and quads since I could walk, and now that they have dirt bikes and quads with automatic transmissions, they're 10 times more fun to drive, that's one reason Polaris ATVs got to be so popular. While you will have to rebuild the A4 after you hit ~450 lb./ft. of torque, you're probably not going to get that far on your budget; if you have a tight budget, don't forget that you've gotta buy clutches every so often with a manual and if you don't know how to drive one, chances are you're gonna need a new one sooner rather than later. So go get an auto for 4k and have fun braggin about how you're tearing up all those wannabe
guys who wouldn't know a double-clutch if Dale Jr. was their Driver's Ed teacher.
