Lt4 Km?
Old Apr 5, 2005 | 04:59 PM
blind527's Avatar
Default Lt4 Km?
Do I have to disconnect the negative terminal from the battery and wait 20 minutes after I install the new KM to reconnect it? I got one cause I got headers/ORY/cutout and don't want any false knock.
Old Apr 5, 2005 | 05:36 PM
LoudmouthLT1's Avatar
No, why would you?
Old Apr 5, 2005 | 05:51 PM
blind527's Avatar
Some people say it may short out a circuit disconnecting the PCM pieces.
Old Apr 5, 2005 | 10:12 PM
If theres no power to the PCM (disconnect neg batt cable) then it can't short anything.
Old Apr 5, 2005 | 10:24 PM
blind527's Avatar
I'm asking if I should disconnect the negative terminal before I unplug the PCM and you asked my why would I do that...now you're saying it can't short anything out...
I asked if I should disconnect the negative terminal, put in the LT4 KM, and wait 20 minutes, then reconnect the negative terminal. All I need to know is if I need to disconnect the battery before unplugging the PCM, otherwise am I risking shorting out a circuit.
Old Apr 6, 2005 | 01:29 AM
monster7's Avatar
yes to be safe disconnect the neg terminal then unplug the pcm
