lt1 tuner program suggestion?
Old Apr 7, 2005 | 12:38 AM
WannaZ28's Avatar
Default lt1 tuner program suggestion
anyone have a recommendation - hows hypertech (is the power programmer III the same as the plus?)
Old Apr 7, 2005 | 01:10 AM
WannaZ28's Avatar
Default power programmer question
im a newbie to this computer stuff, is the hypertech power programmer III same as the programmer plus?
and do you recommend the hypertech or something else?
Old Apr 7, 2005 | 02:32 AM
TwoFast4Lv's Avatar
LT1 edit or Cats will give you alot more for less
Old Apr 7, 2005 | 08:38 AM
N20LT4Bird's Avatar
Yes, dont bother with the hypertech.......not worth the money. IF you want to program the PCM send it out to Ion at madz28.com or Ed Wright. Much better programming for less money......
Old Apr 7, 2005 | 10:39 AM
WannaZ28's Avatar
i just want to do a little tuing, and something that can read the error codes for me
where can i get Cats or lt1 edit? have looked on the internet and couldnt find anything
Old Apr 7, 2005 | 10:53 AM
FIREHAWK #07's Avatar
... a Hypertech can be usefull for some things.... (when you change gear ratios, raise rev limiter, fans can be turned on @ 180*, thermostat open @ 180*) If you pick one for cheap it is an OK buy, but if you want to gain some ponies might want to consider getting a mail order tune, or better yet a custom dyno tune.
Old Apr 7, 2005 | 10:57 AM
TwoFast4Lv's Avatar
http://www.tunercat.com/
there is one of them
