oxygen sensor questions
Old Apr 11, 2005 | 06:07 PM
back in black's Avatar
Default oxygen sensor questions
i just installed my 1 wire o2 sensors on my 94 Z and did a test drive. there are no check engine lights but it still stays in open loop.
im guessing its probably because of the heater curcuit being open open so i guess my question is. What size resistor should i put in the heater curcuit. or would that fix it. the sensor reads fine according to my a/f guage and take virtually no time to heat up enough for a clean signal.
i just need to figure out what to do to make the computer think the heaters are still hooked up.
