Just ordered clutch.. SI record here i come
That record is soon to be broken! Good luck
I have went 8.60 and 8.59 with just !spare/jack, !front sway bar, muffler and CAI, with MADZ28 tune, launching at 5k on stock replacement clutch with MT DRs and skinnies. this was with 1.95ish 60', MPH was lower at about 79/80 but that will soon change.
Those times are low 13s, I know that is a far cry from the 12.5s but I am pulling stuff off the car and putting in the 12 bolt, I got front suspension waiting to go on. i hope to be less than 3400 if not in the 3300 range before I go real nutty on weight reduction!!
Just drop the Y-pipe, put a jack or something under the rear of the tranny, remove tranny brace, tq arm, driveshaft, and slave cylinder/clutch fork.
Unbolt all the bolts that go from the tranny to the bell housing, then i used a floor jack with a bunch of pieces of wood on it to slide the tranny back, releasing the input shaft from the clutch.
Remove the bell housing and old clutch/flywheel, put in your new goodies, and reassemble.
Note- make sure no one pushes the clutch with the slave disconnected, it will blow all its guts out and you'll need a new one. Dont ask me how i know
Craig you *****! Always trying to make a buck
I try to scrounge you up some money and buy you a beer at Year One on Saturday!
I'll be glad to take that beer!! as long as you'll drink one with me
Is your car a 6spd? The record that this post is reffering to is the LT1 6SPD Totally stock internal record. Sar2k owns the BOLT ON record. His car is an A4 and he also has springs and rockers. GreenbeanZ28 owns the BOLT on Record for 6spd cars @12.34.
Stock internal 6spd record is 12.48
stock internal Auto record is 12.26
I'm also trying to do it being basically at full weight. My raceweight is 3505 which is no featherweight by all means.
SO, when do you run?
I know is not Actual Full weight, thats why i said basically at full weight
I just remove the backseat, front passanger seat, floor mats etc. Nothing crazy at all. The car still has the bumper supports, airbags, all stock springs, shocks, k member etc. I also have the 12 bolt that adds weight. I weigh 165 so that helps. My actual curbweight is ~3340.As soon as i get my clutch in and break it in, I'll be at the track. Probably wont be for a few weeks. I'd like to run in some half decent air too...
