where do you think i will be at??
Old Apr 21, 2005 | 12:17 PM
urbangreenlt1's Avatar
Default where do you think i will be at??
lt1 383ci 5.7rods all of the good stuff
hooker long tubes and true dual
comp cam 306
stock lt1 heads w/ 2.02 and 1.60 also fully ported with 1.6rr
intake and everything portmatched
58mm tb and 42lbs 255gph pump
ele water pump
msd
and a 200 shot wet for the track.
stock rear end with slicks and skinnys
i will go to a 3.73 set up
Old Apr 21, 2005 | 12:19 PM
ZFan88's Avatar
About halfway down the track with your rear smoking
Old Apr 21, 2005 | 01:51 PM
Jordan57's Avatar
It's all in the heads....depending on the port job you could be running mid to low tens on juice to 11 teens on it at the track. I wouldn't be surprised to see 420rwhp out of this...although a slightly more aggressive cam would be better imho since the 306 is smallish for a max effort motor and also isn't ideal for spray with the 112lsa...but it should still be fine. Save up for a rear end...
Old Apr 21, 2005 | 01:53 PM
Jordan57's Avatar
also what type of tranny are you running? because stall size, tire size, suspension setup etc etc will determine a lot of what times you are going to cut. Also vehicle weight and who is doing the tuning?
Old Apr 21, 2005 | 02:07 PM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
.....look at getting a rear end...not going to go too far on that 10 bolt w/that power.
Old Apr 21, 2005 | 03:45 PM
97M6Formula's Avatar
Dont even attempt it on the ten bolt or youll be disappointed. also for the spray and the stroker you should get a cam to accent it. Ie:236/245 114 lsa with a little more lift on the exhaust side like .569/.580 and dont you worry bout where I got those specs from but something like that would help you especially if those heads flow good. remember a big cam in a big motor isnt so BIG anymore.
I think youll put down about 420 also and a real good amount of torque
Old Apr 21, 2005 | 05:19 PM
urbanhunter44's Avatar
Yeah I think you'll pull an excellent 60 ft... and then skid off the track as your rear end breaks into 50 million peices.
Old Apr 22, 2005 | 12:39 AM
ahah i know about the rear-end i'm saving up to get something way better.
i'm running a 6speed.
25thAnnivTransAm- you think i will even go the 60ft?? on slicks more like 6ft!!
i was going to do a different cam but this one was free and brand new- after some runs and see what kind of power i'm making i will start looking for a different set up!
what stage clutch should i look into?? or what kind of clutch? what about a twin disc!?
thanks for all of your guys help!
Old Apr 22, 2005 | 12:55 AM
DO NOT BUY A SPEC! Just buy a street twin and be done with it. I went through 2 stage 3s the damn spring popped out of the disk after 2000 miles and I broke it in just the way they said to.. It never even saw a dump above 3500...I have a street twin and many high hp cars have been running with no probs
Old Apr 22, 2005 | 01:28 AM
SS MPSTR's Avatar
Depends on how good the heads are. I'll guess 380~400rwhp.
Old Apr 22, 2005 | 08:15 AM
WhtLT1's Avatar
With a 6 speed and that kind of power on any kind of a sticky tire (even a DR) your stock rearend is gonna go KABOOM! And since the motor is out and ur building it y not just spend another 300 on the cam that's gonna net u so much more (power and fun )
Old Apr 22, 2005 | 11:01 AM
Jordan57's Avatar
sweet...yeah a cam swap would be cake after all this labor. In a 6 speed car the rear end is going to be taking a beating with any aggressive driving...i would seriously look into some suspension to eliminate wheel hop and stuff like that so you dont go breaking **** on street tires. DONT HOOK...which I'm sure you know that already. For a clutch...I had a centerforce dual friction for about 3 yrs and 30K miles with lots of aggressive driving...clutch dumps etc.... There are many horror stories about the spec stage 3....but I've only heard good things about the 3i and hybrid clutch. I've also heard horror stories about Mcleod Twins...I mean face it **** can happen with either clutch obviously, but spec has had more negative feedback, prolly cuz more people buy them because you could buy about 3 or 4 for the price of one mcleod twin...just a thought. My vote...is for the centerforce.
Old Apr 22, 2005 | 11:16 AM
More like 6 inches.
Definetly get a new rear in there before you go playing.
And dont get a SPEC clutch, they're garbage. The centerforce ones are alright in my experience.
Old Apr 22, 2005 | 12:48 PM
But the reason why a mcleod costs so much is because it comes with a master which is billet not plastic like the stocker, a new flywheel, pressure plate and two clutch disks...The only people that have problems with the mcleods are the ones who didnt put it back together exactly the way it came with the shims lined up right. Plus tbyrne has group purchases all the time on them and I paid 895 to my door for it. A spec 3 is 500 bucks and waaaaaaayy more hard to drive than a mcleod although its still not bad
Old Apr 22, 2005 | 02:30 PM
Jordan57's Avatar
Originally Posted by 25thAnnivTransAm
More like 6 inches.
you have an A4!?!?!?!.....hmm....well in my experience the specs work good...just more finicky..and yeah i heard about the group purchase with the mcleod..thats a screaming deal. my centerforce was 750 with new hydraulics etc...but no flywheel :-(. Still lives right now and holds great.
Old Apr 24, 2005 | 08:29 AM
96ramair's Avatar
i love my spec 3 clutch, i think it does a great job
Old Apr 24, 2005 | 09:45 AM
Jordan57's Avatar
also if you notice the ls1 guys are the ones having problems with the spec's not lt1's. different clutch setup entirely
