LE or AI Setup on Strokers
Old May 4, 2005 | 09:40 AM
METALBEAST's Avatar
Default LE or AI Setup on Strokers
I know alot of people are using LE1, 2 & 3 as well as Advanced Induction top ends on stock bottom end LT1s and getting 400+ RWHP easily. Anyone running a Lloyd Elliot or Advanced Induction LT4 or larger ported castings on a 383 or 396 setup? I was wondering what kind of numbers were being put up with these setups.
Old May 4, 2005 | 08:13 PM
hvyss's Avatar
A good friend just had AI do a solid roller setup for his 95Z 383 using Trick Flow heads ported and flowing 310cfms@.600 lift, a 252/262 duration custom grind Comp Cams cam on a 108 LSA, ported LT4 intake, 3/8 pushrods, 7/16 rocker studs and solid lifters. We are gong with the stock PCM for now with a PCM For Less tune " Bryan Herter" with 38lb Delfi injectors. The 383 is using a Eagle forged crank and H beam rods and splayed caps and SRP forged flatop pistons. We are also using a Mosier 12 bolt conversion with 4.10 gears, turbo 350 trans and 4400 stall. When completed will post dyno numbers. We are hoping for high to mid 10's on motor. AI is estimating 500-550 RWHP. We will see. Not crazy about the 108 LSA due to that he does plan a 200-250 shot on NOS.
HVY SS
Old May 4, 2005 | 09:17 PM
Alex94TAGT's Avatar
Hey Jeff~
Lloyd Elliot is porting my stock LT1 castings, and Bret Bauer (SStrokerAce) is working with Lloyd on the solid-roller cam. Going to be a 383, but it won't be n/a.
Lloyd is a GREAT person to deal with -- he's been a huge help to me in this buildup. We've exchanged numerous e-mails, and he always takes the time to answer your questions. I wouldn't hesitate to recommend him just from what I've seen so far.
Old May 4, 2005 | 11:01 PM
METALBEAST's Avatar
Thanks guys, but I am not interested in a solid roller setup. I am looking for a hydraulic roller cam setup. Sorry if I am being so short, but just got back from a car club meet and the Ls1 is god nutswinging bullshit just made me pissed off and want to
Old May 5, 2005 | 12:28 AM
skinnies's Avatar
I didn't keep my 383 running for more than 700 miles, but it did run the times in the sig on the shakedown pass. I was planning on hitting 10.90's n/a on the HR cam with that setup which shouldn't have been much of a problem.
Old May 5, 2005 | 04:31 AM
Alex94TAGT's Avatar
Jeff -- I wasn't suggesting that they only put together solid-roller setups. That was just something I changed. Lloyd's packages normally include hydraulic roller cams. Sorry for any confusion~
Justin -- I hate to ask, but what happened after 700 miles? That's horrible -- sorry to hear...
Old May 5, 2005 | 05:31 AM
atljar's Avatar
Ive got a set of AFR 210s fully ported by AI.
383/afrs/GM 847/12 bolt
Shakedown pulls were 401rwhp with dead on Air/Fuel. It was pulling 8 degrees of timing. Something else was wrong up top too, it made the 400 at 5500 and then nose dived not revving any more.
Havent really tried to figure out the problems since i bought a new cam for it and its all getting torn apart anyways. New cam is a solid, shooting for high 400s+
Old May 5, 2005 | 06:19 AM
skinnies's Avatar
Timing chain broke
Old May 5, 2005 | 06:42 AM
METALBEAST's Avatar
Looking for 450 RWHP minimum. Any more people running similar set ups?
Old May 5, 2005 | 06:58 AM
skinnies's Avatar
You should set a et goal not a peak rwhp goal. Just my opinion though.
Old May 5, 2005 | 11:05 AM
METALBEAST's Avatar
Well in a roundabout way I have. My goal is low 11s/high 10s(which will require some serious suspension) with 120s traps. I want a minimum of 450 RWHP for this.
Old May 5, 2005 | 11:08 AM
METALBEAST's Avatar
Well, I guess the next step is emailing Lloyd Elliot. Anyone have the address?
Old May 5, 2005 | 12:53 PM
RealQuick's Avatar
nighttrain66@msn.com
Old May 5, 2005 | 01:40 PM
n2oblkz's Avatar
www.eportworks.com
Old May 5, 2005 | 07:44 PM
Snow Dog's Avatar
i think either will be fine honestly. youll need to talk with each other and see what cams they recommend. i feel that the cam specs chosen will determine which head will work better. i say this because runner volume and velocity should be close between the two and the cam desired has to work with the runner CC and the velocity of the air. again i think either will be fine. personally id like to build a 396 and i will be looking into lloyd porting some LT4 based heads. be it AFRs of GM castings. most likely AFR 210s though for me.
Old May 5, 2005 | 07:50 PM
METALBEAST's Avatar
Thanks for everyone's help!
Old May 5, 2005 | 08:49 PM
'68LT1camaro's Avatar
Another vote for Lloyd. He's a super helpful guy. Just E-mail him. He'll set you up with whatever you want. Just let him know what your goals are.
Raymond
Old May 6, 2005 | 12:02 PM
flyinZ's Avatar
Bret Bauer(which does LE cams now)He could set u up with a whole combo, not just a cam...I just got a HUGE HR cam from him for my 383..It wont have a lope to it, it'll have a chop,heh. If I can stick the tires, I hope for low 11's n/a, but we'll see how everything goes.
Old May 6, 2005 | 12:04 PM
RealQuick's Avatar
Bret seems to be indepsosed at the moment. I emailed him and pm'd him and havent heard back from him yet (first email attempt was on 4/29). I am just going to stick with cam motion.
Old May 6, 2005 | 12:06 PM
flyinZ's Avatar
He's usually on cz28 more than, LS1tech..I'd make a post in the LT1 forum about him..He'll respond pretty quick..
