oil pump change
Old May 14, 2005 | 02:21 AM
SSRZ28's Avatar
Default oil pump change
what procedure has everyone been using to change their oil pump?
Old May 14, 2005 | 03:13 AM
skinnies's Avatar
here's how I just did mine, well pickup tube fell off, but we had to take out the oil pump so it should work. Support the motor via a hoist, undo motor mounts.lift motor as far as you can, then undo the kmember bolts until they are only a few threads in, then it drops down enough to take off the pan. I had to remove the starter and ypipe since I"m running stock manifolds.
Old May 14, 2005 | 05:32 PM
SSRZ28's Avatar
how long did that take? did u touch the tranny at all? k-member bolts, theres like 6 right?
Old May 14, 2005 | 05:52 PM
brandboZ28's Avatar
I did mine just by dropping the pan. I had to jack the motor off of the mounts but didnt have to drop the k-member. I did it while changing a cam so I cant say how long it took but its not that big of a deal. Pretty easy over all. Id upgrade the pump driveshaft as well while youre in there.
