Question of HP Gain
Old May 22, 2005 | 08:22 PM
ThumpersZ28's Avatar
Cool Question of HP Gain
Hello
Today the air condition compressor froze up and the main serpatine belt broke....had to have car towed home.
Been looking on ebay and have found the 1LE A/C Delete set up....
Question is of corncern.....How much HP gain would I gain if i was to use this delete set up and remove the added weight of some of the a/C .
Car has the T-Tops and at summer they are pulled out pretty much anyway....
Air condition is t-tops out, windows down and traveling at 100 + MPH
thia setup would be running on a bolt on plus 350 LT1
Michael "THumper"
Old May 23, 2005 | 04:21 PM
96capricemgr's Avatar
The compressor only runs when it is needed and I believe shuts off at WOT so you net power gain would be nothing, well maybe .001 because I bet the delete pulley weights less than the ac pulley. You would realize some weight savings.
Old May 23, 2005 | 08:42 PM
FIREHAWK #07's Avatar
yes the AC shuts off in WOT.... and I KNOW YOUR NOT FROM TEXAS!!! no one in there right mind would take off their AC in this TX HEAT!!!! well some of us might.....
Old May 23, 2005 | 08:53 PM
blk94z's Avatar
You got that right, You have to be crazy to take off a/c in this Texas heat. Do not really know if you gain any horsepower from getting rid of it.
Old May 24, 2005 | 10:13 PM
94'BLKBRD's Avatar
What Part Of Pomona Are U From Firehawk #07????
