Port/header interference
Old May 24, 2005 | 10:32 PM
ro9397's Avatar
Default Port/header interference
My GM Fast Burn crate motor has "D" shaped exhaust ports, requiring "LT1/LT4-type exhaust header flanges".
Only Edelbrock makes air-tube equipped headers this car needs to pass emissions tests. The header tubes alternate between 1-5/8" & 1-3/4" OD to maximize scavenging effects. He said the 1-3/4" pipes will clear the D ports, but the 1-5/8" pipes will slightly block the ports. Two tubes per V-bank will clear the ports, two tubes per bank will have partially blocked ports.
The tech continued, saying that because the performance is generated upstream in the head, the four partially blocked ports won't decrease power. He said air leaks are the only risk, & that a tight seal would result using Fel Pro gasket #1407 (may need minor trimming).
Do you folks agree with the Edelbrock tech, or do you believe the blocked ports will impede performance? If so, how much hp might be lost? I want this motor, but with all 385 hp, & without the high cost of custom headers.
(I only repeated this post from another forum because there were no replies.)
Old May 25, 2005 | 07:05 PM
WILWAXU's Avatar
No replies in the LT1 section?
Old May 26, 2005 | 08:23 AM
Mystic97z's Avatar
i know jet hot makes emission leagal longtubes for lt1's. (d ports) i had them on my 97. also i don't know if i'd go for that blocked port stuff...that will make hot spots on your valves.
Old May 26, 2005 | 01:46 PM
nick@kooks's Avatar
Though it's true that exhaust flow travels considerabily more through the top portion of the port, I wouldn't install a header that masks the ports at all. At higher engine speeds, impeding exhaust port flow can and will have a negative effect on overall performance. Of course how much it's affected is relative. When we designed our flanges for LT1's these issues were addressed. We gave ample room for stock and even highly modified port outlets. Nick "Kook's Headers"
Old May 26, 2005 | 08:17 PM
Snow Dog's Avatar
could you not use TPiS long tubes for the LT powered C4s? they have the air fittings.
