Rotate/Remove Coolant Tubes on Water Pump?
Old May 26, 2005 | 10:36 AM
Birdie2000's Avatar
Default Rotate/Remove Coolant Tubes on Water Pump?
http://community.webshots.com/photo...353759490VoGpYs
This tube interferes with my blower brackets. Can it be rotated to face downwards without any leaks? Or, can it somehow be removed and reinstalled, or a new one installed, facing another direction? Worst case scenario I'll have it cut off and a -AN fitting welded onto it, but that really is a last resort.
Old May 26, 2005 | 12:54 PM
skunkdya's Avatar
It is press fit in, if you turn it, you may loosen the press and it will leak. My idea would be to pull it out, tap the pump and put in a 90 degree fitting that is threaded on one end and tube fitting on the other. Face it down and you will be ok. I pulled them out, tapped them and put in plugs since I don't have heat.
Old May 26, 2005 | 12:56 PM
65caminotp's Avatar
im with skunkdya! do that!!!!
Old May 26, 2005 | 01:15 PM
Birdie2000's Avatar
This coolant line goes to the oil cooler from what I can tell, the one on the left was already plugged by the previous owner. Which ones connect to the heat, the one on the left, correct?
Old May 26, 2005 | 04:35 PM
Ken95Z28's Avatar
They are pressed in, I removed mine and tapped it and than put a plug in it. I have no heater core at all. Take a torch and heat it up and pull that sucker out and do what you want.
