PCV Valve vs Breather
Old May 29, 2005 | 03:05 PM
96capricemgr's Avatar
With the sealing fuel caps on todays cars isn't the evap system needed in order to allow some air into the tank? If you suddenly run out of fuel with 1/2 a tank try unscrewing the fuel cap as you might vacuum lock the fuel system as the fuel level goes down.
Old May 30, 2005 | 02:08 PM
The LT1 That Could's Avatar
Originally Posted by HBHRacing
The fact that you can put on a breather and say that it "seems" fine doesn't mean anything. Jus because you don't feel teh changes doesn't make it less real. Your car now has a mild vacuum leak. The fuel addaptives will correct for it but that gives you less room for error should another lean condition pop up.
my thought exactly, escpecially with how proned my car is to having small backfires from the nitrous (stock converter and even with the 3200 pill, it still tends to want to "fart" a little)
Old Jun 3, 2005 | 02:55 AM
crAzy95Z28's Avatar
i have a breather on my passenger side valvle cover. shold i put the tube back on?
Old Jun 3, 2005 | 10:00 AM
HBHRacing's Avatar
It's up to you. Do you want your system to work 100% correctly? If it was me, I would.
Old Jun 21, 2005 | 05:58 PM
monster7's Avatar
does anyone have a part number for the vent tube mine is trashed and i threw it away when i tore down the motor and the dipshits at the dealer cant find it in their system.
Old Jun 21, 2005 | 05:59 PM
monster7's Avatar
is this correct CCV hose 10128365
