Torque Converter
Old Jun 5, 2005 | 03:26 PM
94'BLKBRD's Avatar
Default Torque Converter
Does Anybody Have The Part# For A Stock Torque Converter For A 4l60e???
Old Jun 5, 2005 | 03:53 PM
blind527's Avatar
What is wrong with yours? I bet you can probably get an aftermarket converter with a higher stall for about the same price, and it also weighs a lot less.
Old Jun 5, 2005 | 04:31 PM
94'BLKBRD's Avatar
i went friday to pick up my car from my mechanic(valve springs) and while i was there i had asked him why was my car taking off so slow ,he responded that he drove the car and that it was the torque converter.he told me the stall is about 3600 and that why it was taking off so slow.he said so it could take off faster i need to go down between 2200-2600,transmission was rebuilt about 3 months ago,before transmission went out car was f**king FAST!!! now it's pretty slow! car wont even peel out at all at dead stop.RACED A 02'CAMARO SS (M6) WITH SLP PACKAGE YESTERDAY ,CAMARO PUT BUSSSSSS LENGHTS ON ME FIRST AND SECOND TIME!!! VERY DISAPPOINTED WITH MY CAR!
EDELBROCK HEADERS
K&N CAI
BORLA CATBACK EXHAUST
MARCH UNDRIVE PULLIES
UPGRADED CAM<< DON'T KNOW WHAT KIND BOUGHT CAR WITH THE CAM
1.6 ROLLER ROCKERS COMPS CAM
Old Jun 5, 2005 | 04:47 PM
blazzin93z's Avatar
I Have a stock torque convertor out of a 93 z28 i will sale for 100$ plus shipping...
Old Jun 5, 2005 | 04:48 PM
TwoFast4Lv's Avatar
I am not sure we have all the story here. How hi does your car rev before it moves?
if all was well before the rebuild i would guess some thing changed then...like maybe they rebuilt the converter and got the Stator in backwards. This will make even the best setup a dog...
Old Jun 5, 2005 | 05:16 PM
94'BLKBRD's Avatar
It Revs Up 3500 Rpm's Maybe 4000 And Then It Begins To Take Off But Sloww. Like I Said Before Car was Fast Before The Rebuild.so What Stall Do U Guys Think I Should Go With>>stock Stall? Or Like A 2200-2600?
Old Jun 5, 2005 | 06:18 PM
blind527's Avatar
That doesn't sound like a converter issue..
A 3200-3600 stall eliminates slow acceleration by putting the RPM range in the powerband. What gears are you running? Something doesn't sound right.
Old Jun 5, 2005 | 06:19 PM
Jordan57's Avatar
It's not that it shouldn't move till 3500 rpms. On a 3200 converter, I only saw 2100 on slicks with the brake on, but when I put the throttle to the floor it immediately jumped up to right around 3300 rpm. A lower stall will not help your car go faster...something else is messed up and causing it to be a dog.
Old Jun 5, 2005 | 06:35 PM
94'BLKBRD's Avatar
Do U Guys Think It Could Be That The Torque Converter Is Bad? Had Transmission Rebuuilt A Regular Mechanic Shop.and When I First Got Car Back From The Mechanic First Gear Wasn't Kicking In,took Car Back And They Told It Was Because The Wiring Harness Wasn't Connected Right.mechanic Finally Connects Wiring Harness .but To Me It Feels Like There's Something Wrong With First Gear
Old Jun 5, 2005 | 06:38 PM
blind527's Avatar
The shop didn't do something right. If they rebuilt that tranny you should have no problems at all. I would demand them to take it out and look at it for free and fix anything they forgot to do or did a sloppy job of.
Old Jun 5, 2005 | 07:01 PM
94'BLKBRD's Avatar
But The Motorsports Place I Got My Valvesprings Done In Said That The Transmission Was Rebuilt Good That It's The Torque Converter, Can A Bad Torque Converter Cause It To Take Off Slow?
Old Jun 5, 2005 | 07:39 PM
The LT1 That Could's Avatar
that would have to be one loose 4000+ stall converter to not even transfer power untill 3500+ rpms....sounds like it was a shitty rebuild!
Old Jun 5, 2005 | 07:55 PM
TwoFast4Lv's Avatar
Either the sprag let go in the converter or the trans is not taking off in first gear
Does the car shift? do you hear or feel it shift in all four gears. I have a Yank 3,800 in my car an I can STILL tell when it shifts every gear.
If it is not shifting down to first you will get the results you are getting. It 'Could" be your converter...but I dought it
SO tell us how she shifts
Old Jun 5, 2005 | 08:33 PM
94'BLKBRD's Avatar
from a dead stop it just revs to 3000-3500 rpm's then it starts to move slow but once it shift's into 2nd it starts to move faster.when it hits third u could hear my car because it's LOUD but the car doesn't move fast. my car hasn't the same after the tranny got rebuilt .when i first got my car(first car,learned how to drive in it) car was 2 fasttttt i would slam on it from a dead stop it would stay there for a good while burning rubber and then take off FASTTT. car seems 2 slow now
learned my $1,500.00 lesson not 2 take a f-body just 2 any mechanic
