Stay NA or go FI?
HEY BUD,
all i can say is do it, do it do it. And make sure you get a keyed hub.
i got a 383 turbo
i think you may need bigger injectors than you got
my old 38lbs were maxed out on my 350 with 10 psi of boost
i know run 50lbers and they are fine.
if you got any other questions let me know
i got a 383 turbo
Im runing a simialr one
224/232 580/580 114 lsa
Thunder racing sells keyed hub for around 75 dollars. It is a must !!!!
The injectors , Im pretty shure are going to be maxed, It may be close,
Dont forget it take around 150 hp to drive the supercharger so you need to
set up your fuel system to handle all of that.
Your duty cycle on the injector is going be huge, They are going to be staying open a long time.
