Knock after cam install
Wat codes is it throwing? and I developed a knock after a cam install too. It was a seized rod bearing though
Kinda common from higher mileage LT1 cars after a cam only install Trending Topics
On my car it throws code 15 which is low temperature indicated, and the fans run a lot more than they should so it never heats up to normal temp. I replaced the thermo becaust old one was stuck open and problem came back so I am replacing the coolant temp sensor tomorrow. Could be why your fans are running all the time. But that has really nothing to do with the knock.
