prolonging opti life
Old Jun 16, 2005 | 01:00 PM
quick93transam's Avatar
Originally Posted by WhiteSSP
So does the Delteq system replace the cap and rotor completely? I'm on the verge of ordering an entire new ignition for my Formula including a new AC Delco Opti, MSD Blaster coil, and a MSD 6AL. If the Delteq would replace the cap and rotor and end up being around the same price then I might as well go with that.
here is a link to the delteq site. http://www.delteq.com/products.htm
you will not need the MSD coil or 6AL so if you have the money to get all that stuff i would put it twards the delteq. if you wanted to get crazy you can get 4 of the MSD coils. i believe PT# 8224 will work. and you can buy a spool of MSD wire and make your own wires too. last i spoke to delteq they would let you buy the kit in different versions. +/- parts of the hole kit.
Old Jun 17, 2005 | 06:39 PM
WhiteSSP's Avatar
I may just save up and get a new Optical sensor and the Delteq system. It would only end up being a couple dollars more, and it would probably be worth it in the long run.
