Which injectors for 230/236
Old Jun 19, 2005 | 01:16 PM
SSRZ28's Avatar
Default Which injectors for 230/236
shoud i go with some 30lbs.
Old Jun 20, 2005 | 11:19 AM
RealQuick's Avatar
Yeah, or you can up your fuel pressure (if you have an AFPR) and have it retuned. this will lower the duty cycle on the injectors. I ran the stock injectors with that cam and LE heads and had 113% duty cycle @ 45psi.
Old Jun 20, 2005 | 11:28 AM
flyinZ's Avatar
yep, 30#'s will be fine.
Old Jun 20, 2005 | 11:29 AM
contraststriker's Avatar
I say run higher fuel pressure. Get higher lb. injectors when you really need them, like for heads or blowers. I'm running 45 psi on my newly completed overhaul with a 230/242 duration
Old Jun 20, 2005 | 08:26 PM
Snow Dog's Avatar
i say get it scanned and if your duty cycle is 90% or over for the car to be in tune get new injectors that are bigger. your asking for a lean condition and a blown piston if you run it at more than 90% duty cycle often.
Old Jun 21, 2005 | 08:33 AM
platniumta's Avatar
Restricted User
I think 30#s will be fine with that setup
