Temp Clutch Safety Bypass
Old Jun 29, 2005 | 12:13 AM
lov2xlr8's Avatar
Default Temp Clutch Safety Bypass
I was cleaning up the wiring under the dash to make it look a little more pretty and in the process I unhooked the relay I was using to disable the clutch saftey for my remote start then promptly forgot how to hook it back up. It's probably for the best, the setup I was using it was disabled all the time. Is there a way to set it up so it's only disable when I remote start the car? I'd perfer that over having it disabled all the time, either way I need the diagram of either of the two because I lost my previous print out. D'oh.
