Still missing above 5000 rpm
UPDATE: got to looking at some old dyno charts and it looks like there were a few misfires which caused blips in my runs. When nitrous was injected, the misses were gone. The two WinPEP charts were with the old optispark setup with MSD Digital 6. The third chart is my recent run at Thunder Racing with the Delteq coils. I also got to thinking that during the old run, my opti was relatively new. For my recent run, I had since fixed an oil leak coming from my waterpump drive so that oil could have possibly gotten in my optical.
who tunning it ??? heads cam combo play a big factor on a stroker.
have you run a data log while on the dyno to see if you see anything weird..
any history codes in the comp.
as far as the oil issue on the back 4 cyl i have no clue what could be up
how long is the cam dowel pin sticking outta the cam.
no history codes been set. mine had several but no light
http://www.mofbody.com/blkchevyz/fmsdyno.jpg
mine doesnt normally do it till around 5800
changed opti's a few times, coils, ignition box, ignition module, added more grounds, changed valve springs... the only thing i havent changed was the bottom end.
I now have about 8K on the clock so that's not really it. The cam has the long dowel pin but I have the first gen opti so there's no conjuction of the pin and the opti. My dad said he would adjust my valves again since that could be causing some blow by and the miss.
