spendage
Old Jul 2, 2005 | 09:02 PM
The95Firehawk#250man's Avatar
Default spendage
soon i will have 3000 dollars what could be done. I need a rebuild and i am looking for 400 plus horsepower what do yall think
Old Jul 2, 2005 | 10:07 PM
brandboZ28's Avatar
355, stock crank, stock rods, forged pistons, heads, cam, spray, and a tune will get you where you want to be with some cash left over.
Old Jul 2, 2005 | 10:44 PM
Brett95z's Avatar
With cash left over? I dont think so.
Old Jul 3, 2005 | 05:27 AM
z28boysteve's Avatar
when I first built my motor I had aproximately $2,500 in it... ran 11.7s with a hotcam N/A on pump gas!
Forged pistons, Lt4 rods(stock) with ARP bolts, stock crank, 4 bolt main, b&bp
11.45:1, home-ported heads, hotcam kit. ran 11.74 @ 112, or about 410fwhp
[edit] add about $750 to that for hooker long tubes and a y-pipe
Old Jul 3, 2005 | 10:33 AM
Fade2blk500's Avatar
Wow your car must 60' like hell!! that's very impressive numbers for that cam. I definitely vote for the forged piston 355 shortblock. I'd get some nice ported heads and a good size cam. If you got an automatic definitely get a convertor! 2800-3000 would be very suitable for the street.
Old Jul 3, 2005 | 12:56 PM
Jordan57's Avatar
I would keep the stock crank, get some eagle h beams or similiar rods w/ arp bolts, forged pistons and just go with a 355. Then go with a LE setup, LE1 or 2 will get you close...but you will still need all supporting mods. LTs, tune, clutch/converter, gears...etc. 3K might not be enough. Then it's only a matter of time for other things
Old Jul 3, 2005 | 01:29 PM
I dunno GMPP rates the powdered metal LT4 rods to be safely good to 500hp, and thats severly under rated, on my one pass before I left for kuwait and it was still misfiring like hell I trapped 118 with 3,400 lbs, about 480flywheel HP, I plan on swapping to oversized valves, a 58mm TB (48 now) and an electric water pump + make it run right to hit 500flywheel..well withing safe.
but then ima spray my 200 shot muwahaha!
and it 60'ed alright with the hotcam and 3000 stall (1.56) but it slowed down to 1.61 with the bigger cam, hopefully a 4,500 stall might get me a 1.4x
Old Jul 3, 2005 | 01:42 PM
brandboZ28's Avatar
If you do most of the work yourself(which I would), its doable.
