SIGH... damn Roller rockers....
Old Jul 7, 2005 | 12:00 PM
FIREHAWK #07's Avatar
Default SIGH... damn Roller rockers....
I am in the middle of installing some roller rockers on the LT1,,,, and for some reason one of the rockers keeps falling off!!! I have set zero lash and given it as much as a 1/2 turn past zero lash.... and it still keeps falling off.... any ideas????
Old Jul 7, 2005 | 12:37 PM
Never mind..... just figured it out....... I bought a set of NON self aligning rockers.... so i must use guide plates.... guess i will be selling these.......
Old Jul 7, 2005 | 01:14 PM
BizZzatch350's Avatar
Moderator
just gets yous some guide plates
Old Jul 7, 2005 | 01:52 PM
RoAdRaGe912's Avatar
Old Jul 7, 2005 | 04:40 PM
seawolf06's Avatar
i thought NSA were better? how do the guide plates work? if you end up selling these, let me know.
Old Jul 7, 2005 | 04:56 PM
z28boysteve's Avatar
guideplates also = requires machine work, NSA are better because it controlls the pushrod better at HIGH rpms, more valve train stability, self aligning is just a simpler but less effective way to do the same. I would get SA if I were you to avoid pulling the heads. also I dont know if ALL guideplates require machine work, but the GMPP ones I bought from thunderracing required a flat space to be milled where they sit.
Old Jul 7, 2005 | 08:11 PM
monster7's Avatar
are these comp pro mag 1.6 NSA if so i have a set of SA pro mag 1.6's i may trade you
Old Jul 8, 2005 | 07:12 PM
romoranger's Avatar
i got some 1.6 rockers to trade you, they are SA and i will thorw cash
Old Jul 10, 2005 | 11:10 PM
97M6Formula's Avatar
I didnt have to machine head at all do use guideplates with pro mag rockers .....Why did it have to be machined?
Old Jul 11, 2005 | 12:55 AM
Brett95z's Avatar
Yeah, no machining is required. You must remove the studs, but it would be wise to upgrade to a 7/16 stud anyways! Guidplates arent expensive, i would just buy them and have the better rockers!
Old Jul 11, 2005 | 02:48 AM
Bawls's Avatar
No machining required here, running GM guideplates ( GM p/n: 14011051 ) with comp hardend pushrods (a must) and comp pro mag 1.6 RR's
Old Jul 11, 2005 | 08:34 AM
and only use GM GUIDEPLATES or you will have problems
Old Jul 11, 2005 | 11:01 AM
I used the GMPP guide plates, and they wouldnt sit level on my heads! the edges hit the casting.......wierd lol If I had pics I would post.
