hotcam vs gm846
www.gmpartsdirect.com
Been told on both of these cam's in my 94 Z-28 350 LT-1 I or you will need tuneing, stall, and gear
Setup I am Looking at is ...GM847 with 1.65 Rockers, auto w/ 3000 stall and 3.73 Gears
12370846 Hydraulic Roller Design
This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 222/230; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 509/528. Valve lash is zero/zero and lobe centerline is 112 degrees.
12370847 Hydraulic Roller Design
This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 234/242; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 539/558. Valve lash is zero/zero and lobe centerline is 112 degrees.
Michael "Thumper"
