1993 intake elbow question???
Old Jul 11, 2005 | 09:34 AM
jrod07's Avatar
Default 1993 intake elbow question???
where can I find aftermarket intake elbows for my 93 TA???
Old Jul 11, 2005 | 12:32 PM
Camaro 0wner's Avatar
Aftermarket? Why don't you cut it off and tape it up?
Old Jul 11, 2005 | 12:55 PM
94strokedz's Avatar
If you remove the resonator tube from the elbow, which is I think what he is referring to as far as cutting it off, RKSport.com has a resonator tube block off plug which will help airflow for like 24 bucks. Also, summit racing has aftermarket elbows for 75 unpolished and I think about 95 polished.
Old Jul 12, 2005 | 11:18 AM
Yes, that is what I was referring to. You said it much more clear.
Old Jul 12, 2005 | 11:20 AM
BizZzatch350's Avatar
Moderator
Any LT1 intake elbow will work, you can use a GM 1LE, thats what I have on my 93. You could also use a trick flow elbow if you wanted to.
Old Jul 12, 2005 | 02:24 PM
State69champ's Avatar
I bought one from jegs
Old Jul 13, 2005 | 09:28 AM
Fahad's Avatar
I bought one from SummitRacing from a while..
Check this out ..
http://store.summitracing.com/defaul...h.asp&x=17&y=7
