gear drives??
Old Jul 13, 2005 | 03:55 PM
BLACKDEATH's Avatar
Default gear drives??
im doing a hot cam kit and was wondering if a gear drive is better then the gm heavy duty timing chain....if so what gear drive should i go with??
Old Jul 13, 2005 | 04:17 PM
ThumpersZ28's Avatar
Cool reply
Hello....
In the question of a gear drive ...I would believe that it would be to noisy for the knock sensor...
I would also like to know if this is possible in a 94 Z-28 350 LT-1....if so I would be installing one...
I had one in another car and loved the sound and the look's I got as I drove the car
Michael "Thumper"
Old Jul 13, 2005 | 04:23 PM
BLACKDEATH's Avatar
you gotta love the sound of a gear drive : )
Old Jul 13, 2005 | 04:52 PM
HBHRacing's Avatar
Can't be used on a vehicle with a knock sensor. besides that you would have to go with an electric water pump.
Old Jul 14, 2005 | 12:44 PM
z28boysteve's Avatar
why not just tune the KS out? or unplug it and use a resistor?
Old Jul 14, 2005 | 02:20 PM
pigpen's Avatar
Originally Posted by ThumpersZ28
...I would also like to know if this is possible in a 94 Z-28 350 LT-1....if so I would be installing one...
Yes it's possible - one of the guys over on camaroz28.com ran one for a short while. I think he took it out due to issues with the knock sensor. But as mentioned, you could program or resistor it out.
Of course, anyone with a non-vented opti would have to convert to a vented opti setup, since you can't find a gear drive set with a cam gear that is keyed for the splined non-vented opti shaft. Also, as mentioned, an electric water pump is neccessary - you can't find a gear drive set with a cam gear that has the stock water pump drive sprocket on the back. Lastly, you'll have to do some serious grinding on the inside face of the timing cover to clear everything. Which means you'll need to grind and test fit till it works or till you grind through the cover
I though about trying it earlier this year when I pulled apart my motor, but the double roller I put in about 2 years ago, seems to be holding up fine..
