387RWHP, little inflated?
Yea, good call, he's gonna need some accurate base numbers, i'll give them a call tomorrow.
so who knows....The point is you'll have a great reference for later parts adding....Jimbob
Originally Posted by 98NBM_TransAm
A LT1 Forged internals, ported stock heads (i dont know the flow numbers), Comp 305-8 220/230 .510/.510 114 LSA, edelbrock shorties, edelbrock catted y-pipe, edelbrock catback, Ed Wright tune (Fastchip), its an A4 car, the guy is claiming 387rwhp but its not pulling like it at all, it has no converter, shiftkit, etc. Is that 387 overrated? i figure it'd need alot bigger cam to do that.
I have done SEVERAL head & "Hot" cam A4 cars that made 360 to 375 SAE. A few have made more. A lot of "built" engines don't. Way more only make 350 or so. The numbers will look better on a Dynojet with a stock converter & gears, just won't go down the track nearly as quick. Hot cam only A4 cars normally makes 315 to 330. Some more, several made less. I have seen some below 300. I have had two or three 383"s below 300 in here. If my base tuning is rich @ WOT on the first pull, I know it is likely going to be a weak one. If the engine does not pump enough air, it doesn't need the fuel.
Some ported cylinder heads are not all that much, and don't make any more than a good cam-only car. If you let your buddy down the street got a flow bench for Christmas do your heads, don't expect much. The heads are key.
Tell him to go find a dyno and see what it makes. Stock gears & converter will certainly make one dyno well, but feel weak. Heck, it might just have 2.73 gears.
Good luck, Ed
Originally Posted by Ed Wright
There have been way too many cars through here to remember them all, and I can't remember that car. Nothing new there, I'm old. Terrible case of CRS. I remember John looking in the dyno computer for that car's tests. We lost the hard drive a while back, so don't have a lot of cars from past years in this one. Not saying we/he didn't, but I don't remember it.
Good luck, Ed
Good luck, Ed
Originally Posted by skinnies
Doubt it made the power, but I made 384rwhp(before my tune) with my cam thats smaller than the cc305 and stock ported heads on a stock bottom end, so baby cams can run good.
387 is doable with the CC305 in the proper setup. You just need to have everything working together and a good set of heads to compliment the cam. Heck, I made 375 to the ground with a XE 224/230, through a cat and with a very smallish set of heads that flow very well (175CC intake runners is what I'm talking about, most ported LT1 heads get hogged out to the 190-195ish range). It's all in the setup, but if there's guys who spent the time and effort tweaking a hotcam and heads car to put 380-400 to the ground, the same results are attainable with the CC305.
