How hard is it to remove the Opti-spark?
Old Jul 16, 2005 | 02:38 PM
mikes02ls1's Avatar
Default How hard is it to remove the Opti-spark?
Is their a special way to remove it? We got the water pump off, so what about this dowl pin I here? Isn't their just three bolts and off it goes? Any seals should be removed and replaced? The car is a 96 Corvette A4..
Old Jul 16, 2005 | 02:46 PM
97M6Formula's Avatar
you also have to pull the balancer off.. After that it should just pop off
Old Jul 16, 2005 | 03:03 PM
sssalah's Avatar
There's on o-ring that holds in tight inside the camshft bore. After removing the 3 bolts just wigle it out.
Old Jul 16, 2005 | 04:49 PM
Jordan57's Avatar
yeah the dowel pin thing just has to do with camshaft swapping applications bc depending on year, you might have a long or short dowel pin and would need to be swapped..but you'll be just fine.
Old Jul 16, 2005 | 05:04 PM
jninan2k2's Avatar
you aren't worthy enough to work on an lt1
