No closed loop
Old Jul 18, 2005 | 10:50 AM
Sotiri's Avatar
Default No closed loop
As soon as my engine goes into closed loop, the AFR shoots up to the 18's (i have the innovate AFR meter). And then according to my scanner, it switches every 2 seconds from closed to open loop. Anybody encounter the same problems? What can possibly be wrong? It is way too lean
Old Jul 18, 2005 | 01:45 PM
HBHRacing's Avatar
don't let it idle when your wathcing. Sometimes it will enter open loop on idle. Bring the RPM up slightly and see what it does.
Old Jul 18, 2005 | 03:38 PM
Sotiri's Avatar
Car runs decent when first started then when it goes into closed loop it goes lean, wideband shows over 17:1 AFR.
Open loop start: 13's AFR
Goes into closed loop and kind of works its way lean. I already picked up the idle and still does the same. MAF looks clean. Going to see maybe i have a burnt o2 sensor/wire.
Old Jul 19, 2005 | 01:14 PM
Sotiri's Avatar
Yup, that was it. O2 sensor was torn from removing that piece of SH** 4l60e about 6 times. Runs in closed loop now.
Old Jul 19, 2005 | 01:55 PM
HBHRacing's Avatar
Glad you got it taken care of. Should run like a brand now beast now
