No Such Thing As Stupid Questions... (iron heads?)
Old Jul 19, 2005 | 03:24 PM
Robbie Boyd's Avatar
Default No Such Thing As Stupid Questions... (iron heads?)
just stupid people, right?
Just to entertain the thought, if I found some used iron LT1 heads off an Impala SS, would it be feasible to put it on my F-body's LT1?
Old Jul 19, 2005 | 03:47 PM
97MysticZ's Avatar
What's a Sticky?
Could I just ask why??
Old Jul 19, 2005 | 05:46 PM
z28boysteve's Avatar
yes, same head basically but iron, and flow much better, however, becuase they are iron, you will not be able to run as good a compression ratio without the detonation issues.
Old Jul 19, 2005 | 09:56 PM
Just curious.
Old Jul 20, 2005 | 01:53 AM
satinleafct's Avatar
I wish my heads were iron, then maybe I woundn't have stripped out so many bolt holes.
Old Jul 20, 2005 | 04:59 AM
sssalah's Avatar
The iron heads may flow slightly better, but so does the 96-97 heads casting 561. IMHO The Al heads are better because they are much lighter and have screw in studs. Answering the original question, iron heads will bolt up fine.
