Headers or Subframe Connectors?
Old Jul 31, 2005 | 10:54 PM
Renegade's Avatar
Default Headers or Subframe Connectors?
Ok, my birthday is coming up, and I have $250 dollars to spend on a birthday present from my Grandparents... now I can't really get the headers I want for $250, but I can get BMR Tubular Subframe Connectors, and save up for the Hooker LT's and buy them myself. But I'm also getting a Hooker Catback from my Mom... so, should I just suck it up and go with crappy headers, or install the catback and worry about headers later?
Also, the subframe connectors are weld-in, I'm pretty good at MIG and TIG welding but I would rather have a professional do it. Any estimates on how much it would cost to have someone weld them in? And any pics of what they will look like?
Old Jul 31, 2005 | 11:30 PM
Renegade's Avatar
I also suppose I could get springs or shocks, is that a better option than subframe connectors for my first suspension mod?
Old Jul 31, 2005 | 11:56 PM
BizZzatch350's Avatar
Moderator
I spent a 100$ on mine from HPE, its worth the money, I have had friends skimp out and get it done cheap, or them selves, they end up messing things up. Worth it to know its being done right the first time.
Old Aug 1, 2005 | 12:02 AM
Renegade's Avatar
Well it be more benficial than springs or shocks as a first suspension mod?
Old Aug 1, 2005 | 01:05 AM
95_Firehawk_Dude's Avatar
I would presonally get the subframe connectors. Great if you have a car with no roof support (t-tops) and will also prevent the "F body dent" on the rear quarter panel that everyone gets from felx.
I paid $70 to have them installed by speed inc. Better then some 'Joe shmoe' to becuase I know they do it right (pull the seats and carpet etc.)
Just my .02
Old Aug 1, 2005 | 01:18 AM
Bawls's Avatar
I wouldn't go with headers unless you can afford to buy the coated ones. So just spend that cash on the SFC's. I spent $150 on the sfc's (BMR Tubular weld in, group buy) and $40 for the install.
Old Aug 1, 2005 | 02:41 AM
Renegade's Avatar
Yeah I think I'm gonna go with the SFC's... but would it be easier to just buy bolt ins, if I use locking bolts maybe? Then I wouldn't have to have someone install them, because I highly doubt there is anyone around here who will do a good job.
Old Aug 1, 2005 | 12:32 PM
Vendetta's Avatar
First thing's first... get the SFCs.
Weld-ins will provide much more structural stability than bolt-ons. Get the weld-ins and have a mechanic weld them in for you. It isn't a hard job.
Old Aug 1, 2005 | 01:34 PM
urbanhunter44's Avatar
Dont bother getting bolt ins. Over time the bolt holes widen from stress, and the SFC's become useless. Weld them and forget about it.
Old Aug 1, 2005 | 02:50 PM
Renegade's Avatar
Yep, that sounds like a plan... I'm gonna try and find someone who can do a good job, off to the phonebook I go. I'm hoping SFC's will help my car hook a little better, or atleast make the ride less ruff.
Old Aug 1, 2005 | 03:42 PM
Vendetta's Avatar
Should provide a noticible difference in ride stability and eliminate a bunch of squeeks and rattles also.
Old Aug 1, 2005 | 04:09 PM
Renegade's Avatar
Yep, after the SFC's I will have my Hooker Exhaust on... then I will save up for some Hooker LT's and Y-Pipe. And go from there, maybe a BMR Trak Pak and Lower Control Arms, Eibach Springs? Then do my Heads/Cam package, Fuddle Stall and PCM For Less and I should be running low 12's.
Old Aug 2, 2005 | 05:44 PM
BawlsZ28's Avatar
I would get LCA's to help with wheel hop in the future!!
Old Aug 2, 2005 | 11:30 PM
Renegade's Avatar
Yeah I plan on doing LCA's, springs and maybe shocks, and maybe a Trak Pak from BMR, but we will see with time. No use having 400HP if you can't get traction
Old Aug 3, 2005 | 01:04 AM
carolinacasper's Avatar
How much for a good pair of LT w/egr and Y-pipe for a '93?
Old Aug 3, 2005 | 02:27 PM
Renegade's Avatar
A set of Hookers is I believe around 400 bucks and near 600 for Ceramic coating, which is worth the money. Plus about 100 bucks for a Y-Pipe etc. Sometimes you can catch deals, and Pacesetter makes pretty good LT's as well. But depending on how much you have to spend go with Hooker over Pacesetter, and Kooks and QTP over everything else if you have about a grand to spend. Go to Summit and check out some sponsers... there might be a group purchase sometime too.
Old Aug 3, 2005 | 04:22 PM
slowmofo's Avatar
Old Aug 3, 2005 | 04:28 PM
SLPHawk300's Avatar
Where exactly are you getting 400hp from?? The thing people often neglect is suspension. Suspension ois key component to reliable, useable horsepower. What is the point, like you said, to have 400 horses and waste them on spinning your tires. I am in the minority it seems when it comes to these cars..i have no built my car to go straight fast. I built mine to handle, and to be fast. My car does pretty well on the strip, but it's on the road course that it excells. It all depends on what kind of use you want out of your car. If it's a daily driver there's no sense in buying the best of the best suspension compnents because you'll never utalize them. Shocks and springs from say QA1 are meant for purposes other than just driving around. A stiffer suspension is uncomfortable for a daily driven car...You need to figure out what kind of drving you're going to do, and then start building the base of your care accordingly. Start with the subframe connectors to prolong the experience of your car, then do the shocks/springs, and all the rest. Remember, suspension is key, and most important to going fast, and using every last horsepower...
Hawk
Old Aug 4, 2005 | 12:18 AM
Renegade's Avatar
Thanks for the advice Hawk, I get what your saying. I'm saying 400HP if I ended up doing a Heads/Cam package. But after I'm done with bolts ons we will see what I'm running. I will probably take your advice and just build the suspension a peice at a time, it's my daily driver for now, not a strip car. I just want to be able to hook up when I'am at the track, I'm sure a stall and drag radials would help quite a bit. SFC's, Shocks + Springs, and LCA's would probably be enough suspension parts to improve handling and traction, I will be doing SFC's, then Headers. Then probably springs and go from there. If I decide to leave the car alone from there I will probably do a hotcam and stall and be done with it. But if I can find a higher paying job (which I'm hoping for) I might be able to afford a good daily driver that's good on gas, and do heads/cam on my Z then go allout on the suspension when I know it will be needed. Right now I'm just figuring out my goals and seeing where it takes me, feel free to throw out any other suggestions you might have.
