Replace Oil Cooler
Old Aug 8, 2005 | 11:41 AM
cmerc's Avatar
Default Replace Oil Cooler
I have a '94 LT1 Z28 Stick, I want to replace the ineffective factory oil cooler with an aftermarket unit, should I simply block the outlet and inlet points on the Rad and pump, or join the outlet and inlet lines, or somthing else.
Old Aug 8, 2005 | 12:16 PM
dhdenney's Avatar
How do you know the oil cooler is ineffective?
Old Aug 8, 2005 | 01:37 PM
cmerc's Avatar
I must confess that "I don't know emphatically" that it's ineffective, but based on it's design, and what others have said, it certainly can't be as efficent as a quality aftermarket unit. Irrespective of all the above that's the direction I intend to persue and thus the original question remains.
