clutch problem?
Old Aug 13, 2005 | 08:25 PM
fattypros's Avatar
Default clutch problem?
lately whenever I come off the clutch, if i put the gas pedal down any farther than for slight acceleration, the rpm's will just shoot up to about 5k almost as if the car is in neutral, but then my speed will slowly increase until it matches the normal speed for that rpm. the only way im able to accelerate even some what like normal is when i downshift, then wait for the rpms to jump up and match the speed, then i can give it more gas. a guy at checkers summed this up to the clutch going out. I bought a new clutch anyhow becuase I am still building up the motor. But some other friends of mine say that it might not be the clutch that is the problem. It's not like the shifter pops into neutral when i slam on the gas, it just takes forever to get going. can anyone help me shed some light on this subject and has anyone had a similar problem? Any help appreciated
Old Aug 13, 2005 | 08:48 PM
blown97's Avatar
Had the same problem after I got my procharger on. Didn't do anything until a minute later when i got up to speed, put in centerforce dual friction clutch, bam fixed the problem. thats all it is bud.
Old Aug 13, 2005 | 10:50 PM
NXSLT1's Avatar
Yer clutch is slipping, it's either wore out or has oil on it. Replace it.
Old Aug 14, 2005 | 12:14 AM
RoAdRaGe912's Avatar
By Brett Foote | 2026-06-04 05:00:17
