prices and suggestions
After that you can look into some exhaust, I don't know what your budget is but there are a lot of very good catback systems around for cheap. You can also get Headers pretty reasonable, if your going big time you can afford a Borla Catback, or Corsa Catback, and some QTP or Kooks Headers. But if your on a limited budget, Hooker, Texas Speed and Performance, Magnaflow, and a bunch of other companies make well priced catbacks that perform. You might also want to look into duals or whatever. Check out LS1Sounds.com, it has a lot of sound clips and info on exhaust. And search the forum for some recommendations. If you decide to do Headers with your exhaust I would look into Pacesetter Longtubes. Spend the extra money on ceramic coating if you have it, it's well worth it. After all that, see how you like the little setup and go from there.
