Why does everyone bash on otisparks??
Raymond
OPTISPARK is great on paper but bad in the application... would you put an electrice station under a waterfall or under a lake??? water pumps leak.. it just happens.. once water is in there your about fucked... also your front main seal has a habit of usually leaking... I've see oil on top my opti before... If it was a great design Gm would continue to use. GM dealerships know it's a bad design.. if you've ever taken your car in and been told it's your opti.. the Tech probably told you this happens all the time.
