cars dead again need advice and help
Old Aug 19, 2005 | 07:04 PM
spcearle's Avatar
Default cars dead again need advice and help
ok heres the deal......i have a 96 z28 that i had a 383 built for...after i got the engine in the opti died on me so i replaced it....at the same time i tested and tried replacing the coil and icm and they seemed to be fine.......well the car ran fine but always had a top end stumble.....throughout the next few months i replaced and checked all plug wires and plugs many times since i was always having problems with them thanks to headers and engine bay heat...well finally got the car running bettere then ever with the final plug wire and plug job and all hell broke loose......the car was runnin great till my opti blew again...this time the rotor screws came out and the opti looked pretty beat up....i put in an opti from summit and wow the thing woke right up like a new car....well now for the prob.......the very next day on the new opti it died and seemed to do the same thing as the last time.....i have good spark at the plugs/good fuel and pressure/pulse at the injectors but it wont start.............i'm trying the icm first and the tearin the opti out again to see if thats it...if it is the opti can anyone tell me what might be blowin them apart now...and help or suggestions will b great
Old Aug 19, 2005 | 11:04 PM
HBHRacing's Avatar
for the no start use this.
http://www.mainstreamtopics.com/foru...p?showtopic=78
for the opti troubles, check the cam dowl pin length. My money is on it being too long and killing the opti.
Old Aug 21, 2005 | 05:18 PM
spcearle's Avatar
ttttt
Old Aug 21, 2005 | 05:28 PM
monster7's Avatar
did you take out the rotor screws and locktight them then put them back in
if you put the opti on straight out of the box that is a very common problem those screws will come loose
Old Aug 21, 2005 | 08:55 PM
HBHRacing's Avatar
Originally Posted by spcearle
ttttt
You didn't like my answer?
Old Aug 22, 2005 | 06:15 AM
spcearle's Avatar
yes i read through everything and compared what i knew and already checked...i'm just looking for as many opinions and thoughts on this that i can get.....i'm just gettin a lil frustrated over here...had the car back since the end of may with over 12 grand so far into this motor alone and have only had it running perfect a few times and i'd like to get er goin and have some fun with it b4 i have to store it...not my idea of having fun always workin on it and tearing it down...lol
