Glowing Headers
Old Aug 25, 2005 | 04:36 PM
cmerc's Avatar
Default Glowing Headers
I have been having idling problems since it started to rain, the car ('94Z LT1)idles fine inside a garage or under a covered service station but as soon as it gets out in the rain (high humidity) it hardly stays running. I suspect it's probably the Opti. A more concerning issue is while looking under the hood in a darkened garage, the Header pipes on # 4 & 6 cylinders were glowing red.
I wonder if those injectors are failing and causing those cylinders to run too lean. Help.
Old Aug 25, 2005 | 08:05 PM
NXSLT1's Avatar
Somebody on here recently had a glowing header problem. I think it turned out to be the opti. Do a search on "glowing header".
Old Aug 26, 2005 | 11:22 PM
dirtybird96's Avatar
mine did this due to plugged injectors
